Envoy / Trailblazer Oil Life System
OK guys, I have a 2002 GMC Envoy SLE, that is, without the driver information center. I have 3200 miles on the truck, so yesterday I changed the oil for the first time. Am running Mobil 1 Synthetic 5W-30. The "Change Oil" light was not on, but I always like to change the oil at 3000. But now that I am running the synthetic I will wait for the light from now on. I followed the directions in the owners manual, regarding resetting the Oil Life System. In my owner's manual it reads: 1. Turn Key to Run, without starting the engine.
2. Press Accelerator Pedal Fully three times within five seconds.
Now, I did this, but is the system really reset?? Is there no indication that it is really reset. Is there any way to check and see if it is really reset? What do you all think?
Thanks.
:lol:
Is that all it said? I thought it was something strange like cycling the ignition switches, then doing the gaspedal w/ the high beams or something strange like that... Honestly, I have mine changed every 5k mi.  I use Mobil1 syn blend, and being it into the dealer.  every other time... That way, every 10k it gets documented, and the dealer resets it... so far, so good. =oD
Yes, that is all it is. Alot of the full size pickups have the same thing.  I was just wondering. My Dad is a dealer and my Uncle owns a service station, so I am not going to have the dealer (my father) change my oil. As long as you have your recipts you have documentation.
My Uncle's shop has used this procedure to reset the light after it has come on. But if you read the owners manual, it tells you to use this procedure every time you change your oil.  I think on the 2003's the light blinks for 5 seconds after you reset it, but not on the 2002's. They must have gotten tired of answering this question and made the change.
I was just wondering if anyone else came across this.
There is an easier way to do it
Go to the oil life indicator
Hold down the Reset button on the steering wheel and it'll go back to 100% oil life.
Easier then the 3 pedal reset used for GM cars/trucks
02EnvoySLT- Sounds great, but if you re-read my post I have an SLE not SLT and the SLE doesn't have the driver information center. Although I agree that is much easier.
:jester:
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
