Ford Powerstroke beats Duramax!
JerzeyKid
Not real suprised.  New engine, new tranny.  Ford is having to prove itself just as Chevy did when the Dmax was released.  I'd be willing to bet that there will be improvements made to the Dmax for '04 model. :lol:
Didn't expect Ford to introduce a new motor/tranny combo and have the GM still come out on top did ya?  It all goes in cycles, Ford just happens to be on top for 03 like GM was for the last several years.
I throughly expect the little Navistar and the Dmax to be some pretty good competition for each other over the next several years.  The Navistar already makes a bunch more torque in medium duty applications (620ft-lbs@1400rpm) and the Dmax is rumored to be at 340Hp for the 04 models.  Got to love competition.   :thumb:
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
    • subscribe to alldata.com, that will have gm's brake bleeding procedure.  and what you have to do likely varies, as if you just replaced a caliper and the MC didn't go dry, you most likely can just do a normal bleed on that corner, but if you disconnected lines at the MC or the abs unit, or let the MC run dry while doing work, you'll have to do a more extensive/complicated bleeding procedure.
