Cooper Ltz 275 60r20
Hoosier Daddy
I am looking at putting Cooper LTZ 275 60R20 tires on my 2007 Silverado 2WD. I am planning on getting a leveling kit soon but can only afford one thing at a time and I need the tires now. My question is this: Will these tires rub using my stock rims, and if so, will the truck even be drivable before i get the leveling kit. My back up is to stick with the original 275 55R20 in the Coopers, but I would really like to add the extra rubber to the truck and the price difference is minimal between the two sizes.
I can't help alot but I put a set of the 275/60r20 zeon ltz's on my wifes 07 tahoe 4x4 with a spacer up front and there is only a minimal rub when turning into a steep driveway. I'm not sure how a 2wd would differ plus no spacer up front but I'm guessing you're gonna get quite a bit of rub.
I had the goodyear wranglers on my truck without a lift and the tires were fine. These tires are 33" in diameter, and I would think that they would fit on your truck...... Is your truck a NNBS or Classic? As mine is an 06.
mine is the newer body style.
thanks. I'm hoping someone out there has tried it without the leveling kit. Can't afford both now and need tires ASAP. Hoping i can get by for a month or two before installing kit. will have to stick with stock tire size if rubbing will be a major problem
I put 275 60 R 20's with a RC level kit in an 08 nbs sierra and I have no rubbing issues at all.
You can't afford a $60 leveling kit??
Buy the tires online and pay someone under the table to install them you will save way more than the $60 for the leveling kit.
$60 leveling kit? where are you getting that at. The cheapest I've found it for here in San Antonio is $350 installed with the front end alignment.
The Rough Country is super easy to install. If you can't do it, find someone who can and pay them in beer. Takes less than a hour with normal hand tools. An alignment is 50-60 bucks.
Rough Country 2"
I put used ltz's on my truck stock height without any rubbing, then I put brand new ones on with a RC kit and not rubbing. Just get the leveling kit it's cheap and easy to put on, but without it it'll prob rub a little
Well I put on the 275 60 20 tires and i have a small amount of rub, really minor though. RC leveling kit is going on this week once it comes in. Thanks for the recommendations. The RC kit does look really simple. I'm no mechanic, but thanks to the internet and youtube, it looks easy enough for me to do myself. Kit plus alignment will be about $130. That beats the heck out of what the shops around here wanted to charge me, and leaves me enough money to have the magnaflow exhaust i want put on next week as well. Photos will follow once I'm all done.
  • 3 weeks later...
Any pictures yet? I put the RC 2" level kit on mine and i am wanting to run those tires with some XD monsters but am worried they will rub, any feedback?
Have you got a picture of the tires on the stock truck (without the levelling kit)?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
