Door Wont Close Unless I Slam It
I just purchased an 04 Denali with 87k miles. I noticed only the driver door has to be really slammed in order for it to close. How do i remedy this? Thanks for all your help.
Is the door saging? If it is the hinges need adjusted. If not I would try to lube the latch, Maybe the latch is sticking?
The door is not sagging, I already lubed the latch. Seems it just needs a good slam to close.
Was thinking the latch on the actual door frame may need to be adjusted. Figured i would ask before i start adjusting things
if the door is not sagging then try just loosening the striker on the body and just bring it out a very little bit at a time untill it closes correctly.
was probably in an accident, when i got a new passenger door on my truck, its a lot harder close, you gotta slam it.
Check the Cab vent in between the cab and bed. Maybe its clogged or something not allowing the air pressure to escape when you close the door.
Ok so once I loosen the bolts to the stryker on the door jam. Is it only gonna move in and out.
Or will it also move up and down. I dont want to make a simple thing more complex. If it moves all over then I will just have a professional body shop adjust it for me, But if i can only get it to inch out a slight bit then its perfect.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
