What Color Are My Keys
ordering a set of leveling keys after talking to a buddy of mine and finding out there's more engineering than meets the eyes in these little bastards but it says they may not work with certain colored keys.
company says to contact GM with my vin.
Maybe someone here has the resource to find out for me..
here's my VIN 1gthk29u86e221145
My 2001 HD has purple keys. There is a purple marker line on them. The 1500's have green keys which is what most HD truck guys put in theirs to obtain more lift.
I believe GM also uses orange keys and white keys.
One of the things I always do is send an email to GMPartsDirect when looking for parts info. They are very helpfull. Give them a try.
--Mike
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
