Voltage Drop At Every Stoplight
rlefeve
I have a 2003 Sierra 1500HD. A few months back I started my truck and it acted like a low battery, but it started.
The next morning, I could not start it. I took the wifes car to work and tried it again after my shift was over. It started.
It ended up not starting on me again so I replaced the battery. That was not the fix so I replaced the alternator.
It starts strong and has not failed me but now when I am at a light or stopping for one reason or another the battery guage drops down to 9 or below and the truck runs really sluggish then slowly recovers, and occasionally stalls.
The cables all look good, I looked for a corrosion but found none. I know electrical problems can be a bear to deal with, has anyone experienced this?
One other thing, it is intermittent, I can always tell if it will happen as my gear shifter indicator is very dim.
Usually surging will drop voltage and usually stall.Do you have a rough idle?Does she fall on its face?Could be a simple brake switch.Could be a bad tps sensor.Does it make a clicking when you press the brake pedal?.Theres a verity of things it could be my suggest is to start with the smallest thing possible such as the brake switch see if it makes a clicking when you press it down and release it.
It does idle rough, but intermittenly. I will report back about the brake switch.
However I have more to add, not sure if it is relevant.
I seem to get a lot of clicking under the hood which I assume is my air conditioning compressor short cycling.
When I was troubleshooting my alternator/battery. I would let it run then remove the negative battery terminal to see if the alternator could keep it running and i hear the click followed by a stall.
my truck is loaded with power sucking features so when I turn on the seat heat, defroster......it acts up.
There were two alternators available for my truck, i do not recall the amperage but it was the recommnedation to go with the lower amperage alternator form the parts counter person. It might be as simple as needing the big dog alternator.
My truck does this same thing but not as often. I noticed the other day that something does click in the dash around the column when I push in on the brake pedal to shift it out of park. Once I'm in gear it doesn't click. What does the brake switch do and how do I replace it?
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
