Bluetooth Balckberry 9650 Issue
Suddenly I am having an issue pairing my 9650 to my 09 Silverado. The pairing has worked well in the past. In the last two week the phone pairs fine but disconnects from the truk as soon as I place a call, then reconnects when the call is done. I had this problem once before and thought I found a solution here. Looking through the old posts I can find anything? Has anyone had this problem or found a solution??
  • 1 month later...
I had the same problem...but mine NEVER worked with my 2009 Sierra!
I tried the Blackberry Bold, Tour and Curve to work with my Bluetooth without any success.
All would connect fine...but when a call came in or I tried to make a call...the Bluetooth connection would fail...when I hung up...it would reconnect.
This is what ended up working...after a LOT of leg-work. This is from the Engineers at GM.
If your BB used to work with the same vehicle, you may only have to pull the BB battery and then put it back it...just a thought. Never-the-less...this procedure worked...with ONE exception...after everything was said and done...I had to delete all profiles...pull the battery on my BB...then reconnect. Then it worked fine...after 4 months of frustration!!!
1) select "manage connections" in the BB menu
2) select "bluetooth options
3) under paired devices, highlight the "General Motors" entry that corresponds to his 2009 GMC
4) press menu button
5) select "options"
6) scroll down to "contacts transfer" and select "Disabled"
7) save changes
test again
We have seen issues where the phone tries to pass the phone book contents and that generation module does not support.
