Fs: 2004 Silverado Z71
I'm going to sell my truck. It has 67k on it, about 12k on the tires. Leather seats, Sirius radio(still have XM receiver, aux plug-in, Husky mats in frt, PM me with any questions you have about it. I will take more pictures and I will take a pic of anything you want to look at. I am the 2nd owner, I bought with 16k on it. The only mechanical issue I've had is the pump rub in the trans case. I repaired the hole and put the plate in it to prevent from happening again. The cluster was replaced under the special policy covering them so that should never be an issue. I put a steering shaft in about 2 yrs. ago, still no knocking, so that will not be a problem again. Last 8 of VIN is 4E400602 for anyone that wants to see the build sheet. Price is $18,500 OBOpost-43526-1297003329_thumb.jpg
nice truck, you should say whether its a 4x4 or not, i know a lot about GM trucks and i cant tell with your truck.
good luck with the sale.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
