2003 Silverado Water Pump Replacement - 5.3 Liter
This is what I did on my 2003 Silverado with 5.3 liter motor at 94k mi. In my case the left gasket was leaking (gasket leaks seem to be the common issue). The right gasket was ok I also replaced the thermostat since it is attached to the water pump and is easy to replace with the pump off. I have seen some good posts on this so I thought I would add my experience with it. It is pretty easy overall, and could be done in less than three hours depending on how long you spend on cleaning the gasket surfaces on the motor.
Parts used
- New water pump ($130 from Napa )
- comes with alluminum gaskets, thermostat oring/gasket and screws for the thermostat
- New thermostat ($26 from Napa)
- Dexcool Antifreeze ($12/gal from Walmart, will need two)
- Distilled water (cheap)
Tools used - mostly Crafsman
- Couple of buckets for the anti freeze
- Fan removal tool - 36mm flavor (borrowed from Autozone)
- 15mm, 10mm, 8mm sockets
- flat head screw drivers
- channel lock/pliers
- 3/8 air ratchet (air tools are fun)
- standard 3/8 and 1/4 in ratchet
- 3/8 torque wrench
Removal
1. Start draining radiator from drain plug
2. Remove plasic engine cover (says Vortec on it) then the Intake hose (will need to open the plastic hose clamp attached to the upper radiator hose for removal)
3. Remove upper radiator hose from water pump (move hose out of the way....does not need to disconnected from the radiator)
4. Remove upper radiator shroud (two 10mm screws, 4 plastic clips)
5. Remove fan (used 36mm fan removal). Mine broke loose with three taps of a hammer. (removes CCW)
6. Remove lower radiator shroud. This is not really necessary but there is nothing really holding it in once the upper is removed
7. Remove primary and AC belt. AC belt is not necessay, but I did not want to get it covered with anti freeze. Both are easy to remove.
8. Cover AC compressor with plastic bag. I did this to prevent it from getting covered with anti freeze when the lower hose and heater hoses were removed
9. Remove lower radiator hose from water pump and two heater hoses. Be prepared for "niagra falls" here. By now you should be able to tighten the radiator drain plug.
10. Remove belt tensioner from water pump.
11. Remove idler pully next to alternator. This makes it easier to access the bolts and gasket surface on the right side of the water pump and is very easy to remove.
12. Remove 6 10mm bolts holding the water pump in and lift out the pump. I was about 45min into it at this point.
13. Clean the gasket surface areas. I used a razor blade and 320/600 grit wet sand paper. There is probably a better way to do this as it was a bit time consuming.
The Napa water pump came with alluminum gaskets with red silicon material molded into the gasket for the seal. I used them without any additional RTV. The felpro gaskets have blue material. Other than that they look the same.
Installation - There are probably several ways to do this, I thought it would be best to alternate tightening the screws for the pump
14. Place two of the three screws on both sides through the new water pump with the gaskets in place then hold the pump in front of the motor where it mounts.
15. Start the two screws on each side, then start the third screw on each side. Make sure the gaskets do not fall off or slip.
16. Install all screws to a pre snug state.
17. Alternate left to right tightening the screws until snug, then alternate tightening until all were torqued to 22ftlbs (I have read several posts stating this is the appropriate torque)
18. Installed the new thermostat using the new scews that came with the pump. I used some loctite on the screws. The new thermostat already had the oring installed.
19. The rest is just the reverse of the removal; tensioner, idler pully, belts, fan, hoses, intake.
20. I filled it up with 50/50 mix of dexcool and distilled water at the overflow. Mine took in about 2.5 gallons.
21. Started it up and let it warm up until the thermostat opened at ~190 degrees. Have an extra mix ready since it will take in some coolant once it starts up, at least mine did. I left the cap off until it warms up.
I did this yesterday and all seems to be ok after some road testing.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
