2000 Silverado Oil Leak Unknown
ok thanks for dropping by at my topic, I have a 2000 silverado 4.3 oil leak i have, replaced the oil seal 3 times, replaced the oil pan (told to do that by a mechanic), replaced the timing chain cover by a mechanic, so far i have spent $1000 on a oil leak that is still leaking, i can see oil on the bottom of the oil pan and on the front of the oil pan and that is as far as i can see because the frame is in my way and i took it to a different mechanic and he told me it was my intake gasket, i think that it is the oil lines but i came here to get someones elses opinion. Also i can here a ticking on the passenger side cylinders i dont know if this is normal or it is abnormal.
Please help if you can thank you very much Drew
After looking at the engine and I found out that the shop that I took it to fowlers car clinic Yukon, ok I found out that they broke a bolt off into the block and just put the other half back into the timing chain cover hole
