Lift Recommendations
I'm looking for recommendations for a lift on my 2000 NBS Tahoe. It's not 4WD and does not have the autoride. Ultimately, I'm just looking to get about 4" of lift total. I'm currently running 265/75/16 BFG AT's with very slight rub at full turn. That would come out to just under 32's. All I really want is to be able to do is run 33's and have a little higher and level stance. I definitely have a little sag on the front end compared to when it was new.
I don't mind a body lift, but I don't really want to go with a 3" BL. I'm not sure if they even make a 2" BL. I'm thinking of some combination of leveling kit and body lift.
Would a leveling kit lift the rear end at all?
i think leveling kits are to level the front to the rear.. meaning no lift on the rear... i think if you put a leveling kit in the front and then depending on how it sits lift the rear just a little bit.. you'll be able to clear 33's with no problem and it will look great without compromising the way it drives....
Thanks for the input. After doing a lot of reading it seems like I can just crank the torsion bars to level it out. I took some quick measurements yesterday and the rear sits about 1 - 1 1/2 inches higher than the front. I was thinking I could put some 1" coil spacers in the rear and lift the front 2 1/2".
Here is my question...do the re-indexed keys affect the rids at all? I'm reading conflicting information. Some say that just cranking the t-bars will create a really stiff ride and adding the re-indexed keys will soften it up. Other say that all the keys do is allow you to crank the t-bars a little more.
Is 2 1/2" too much to crank the t-bars?
I've seen the Rough Country and Ready Lift leveling kits. What I'm trying to figure out is if the torsion keys are necessary.
In other words, will replacing the torsion keys keep the front end geometry closer to stock than just turning the t-bars?
i had torsion keys (leveling kit) in a 01 f150... before installing the keys.. i cranked the torsion bars... it gave me the lift but it was stiff as hell... then installed the keys and had the same height as i did with the bars cranked but very soft ride... what it does is it relocates the torsion bar in a way that with the leveling kit the minimum height (softest) actually is the highest or what we know as "cranking the bars" with the stock keys (stiff ride)... so you wont get more height with the leveling kit than cranking the bars! but you'll get better ride quality...
oohh but be careful! you CAN crank your bars with the leveling keys! and it will go up another 2-3in but this will cause you to mess everything up! ball joints, cv joints, shocks, everything you can think of :P trust me! leveling torsion keys are designed and assure you no damage and great ride quality as long as you dont crank the bars!
That's the information I was looking for.
I really like that RC leveling kit. It comes with shocks, keys and poly coil spacers for only $260. The only thing is that it says it's for a 4wd. They don't list one for a 2wd. I don't see what the difference would be.
Anyone here have any opinions on this lift and whether it will also work on a 2wd?
RC Leveling Kit
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
