Rear Lift & New Shocks & Add-a-leafs
so basically my shocks are worn and i need new ones. im looking at bilstein 5100s, but what i dont understand is that there isnt a front shock option for a non-lifted truck? there are rears, but no fronts. is this correct? also, cranking the torsion bars isnt considered a lift right even though by cranking the front doesnt it cause the shock to be at rest not technically in its at rest position, but slightly extended? i might be better off with the B6s (but then there might be an issue with the rear- see below- as they only come in stock heights). also, how do these compare with the stock z71 shocks? id assume theyd be better overall?
in addition to new shocks id also like to raise the rear an inch or two to also help with the sag. is an additional leaf really all i need to lift the back? (see: http://www.4wheelparts.com/Lift-Kits-Suspe...p;t_pn=SUP2580). also, does this count as something of a suspension lift? would i need to get a shock thats designed for a 2" lift (as that would be about what id gain with an added leaf)?
and lastly, how long to leaf springs usually last? i dont haul with my truck on a regular basis (moreso the past 2 years though since buying the quad), but im close to 120,000 miles and i put on the current lift and tires between 50 & 60k. im sure the larger tires and wheels have had an effect (its like having a constant load no?). should i forego an added leaf and replace them all? how do i know if the leaf springs are worn? also, since i do put the quad in the bed im looking for something that will be a little stiffer and sway less when its up there- as it feels like the truck is swaying a little more than it used to. what about leaves from a 2500? will those bolt up and give me a few inches more? but then again, would i need a lift adjusted shock?
sorry if its a little confusing, but thanks for the help.
I don't know about the shocks, but I can tell you the 2500 leaves with bolt right in. Leaf springs should go as long as the truck I would think. Unless there is a broken one.
interesting. thanks. would the 2500 springs sit higher if put on my truck you think? since theyre probably stiffer and meant to handle more weight, and theyre supporting a lighter frame, i would think on my truck they wouldnt flatten as much when unloaded?
The 1500 spring run that spacer block. The 2500 does not due to haveing more springs. So the height would be the same. When I put them on my last truck I left the block under the 2500 spring pack. I think it will get you 2 inches hight in the rear. If you want a little extra leave the blocks in. If not remove them.
thanks. how much heavier duty are the 2500 springs? or are they the same and just stronger because their is an additional leaf? and thinking about it i think i would require a longer shock in the rear- not sure about the front though.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
