Rims On Truck
rws262
I want to put these rims on my truck:
http://www.tirerack.com/wheels/WheelCloseU...&sort=Brand
What kind of lift would i need, if any, for the wheel spacing? Anyone else have Mamba wheels on their truck and how are they?
here's a pic of the rims on the truck:
http://www.tirerack.com/wheels/MiniWheelSe...rue&sw=1843
any specific tires recommended?
Thanks for the help.
Since it's got a pretty positive offset(+30mm), you could pull off those rims without any lift, but a leveling kit would be nice with those wheels. Mostly depending on what tires you go with though.
I have no idea. The tires i have are Goodyear LS-2, 275/55 R 20 from factory. I like these rims but dont neccesarily like meaty tires. So i need to find out if the tires i have will fit on 9 inch wide rims?
If that +30mm offset is right, I don't see why not, they'll only stick out a tad more than the stockers. Now, the issue of the rim width, how wide are the stock 20in. rims?
Factory is 20x8.5 +31 offset
what is the opinion on the Goodyear LS2's? Are they a decent tire? Thinking about Pirelli ATR's from tirerack.com? Any suggestions/ experience with tires?
I have had crossovers with them, they are great on dry highways because they are quiet, however the grip isnt great but on a truck that doesnt really matter. In the rain they really arnt that great either and in snow just forget about it.
you mean the goodyears or pirellis?
Look at the reviews on tirerack for street tires. I personally like the look of all-terrains or mud-terrains, especially if your getting black aftermarket wheel.
If your replacing the tires you should think about getting a bigger tire. Im about to pull the trigger on 275/60/20 Cooper Zeons
Thanks for all the advice. Im very ignorant to all the tire/rim stuff.
Cooper Zeon LTZ's correct? What is the difference between 275/55/20 and 275/60/20. 20 is the rim size, 275 is the tire width. What is the 60?
60 is the aspect ratio.. it means 60% of the width.. or in your case 60%of 275 mm =165mm
the 55 series is a 32" diamter tire and the 60 series is a 33" diamter tire. You can run the 60 series tires if you install a leveling kit
