Help.....gm Oval Step Mounting Hardware
Can anyone tell me where I can find the mounting hardware for a set of GM 6" oval step bars? I am missing the nuts and bolts that mount the brackets to the back side of the rocker panels. Any help is greatly appreciated.
If you bought your steps new, should have come with them.
I bought them used.
Hardware you need
M8 x 30mm bolt - QTY 16
U Nut QTY 12 (reg cab)
16 (ext cab)
12 (crewcab)
instructions do not list part numbers
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
