Wanted: 2007-2011 Jumpseat/lt2 Console
looking for a black(ebony) flip down center console with the 3 cup holders in the front, or a black(ebony) Lt2 console to put in my 2007 you can call or text 231-288-8880 thanks guys
anybody?
I have one that I removed out of my 09 Silverado. It is ebony, fold down jump seat, storage under seat, three cup holders. Removed when almost brand new.
Where are you located? PM if interested.
reply sent....
very interested, please check your pm's
Try this site if you don't get any reply's www.copartfinder.com .When you enter site you put you search critria in ie; year make model and your zip and it shows evey truck with detailed pictures from wrecking yards starting with the closest ones in your area and gives all contact info. Just my $.02 worth. :thumbs:
  • 2 months later...
I am looking for one as well if anyone has one for sale please let me know.
Thanks.
I will have my 3 cup holder jumpseat in ebony out of my 2010 HD after 6/13 if anyone is interested. I am on Long Island, NY and the jumpseat is in mint condition as my truck is not a daily driver and it only has 4700 miles on it.
  • 1 month later...
Just a dumb question here. Why are so many looking for the jump (middle) seat? Do you all have the full center console? My 2010 sierra has the middle seat and I was thinking of removing it for the full center console. Mine is Ebony. Where can I buy the full center console?
I have the jumpseat out of my 2010 Sierra, ebony, but, has two cup holders. My truck is an SL. Only posting here cause so many looking, and most do not have location in their profile. I am in Canada if that helps anyone out.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
