Convert Silverado Wt/ls Into Lt
Hello Everyone!
I have a 2008 Silverado LS - 2WD/Reg. Cab - 74U Victory Red that I would like convert into the LT style as far as looks are concerned. I am looking for a list of interior upgrades that would need to be done in order to accomplish this task. I know the logical thing would be trading my truck in for that model but I paid pratically nothing for this truck brand new (15k less than retail) so I would like to keep it.
The main things I would like to know:
Differences in Dash, Radio, Seats and Trim.
Does the LT have body color mirrors and handles
Can I add fog lights?
Is it easy to add steering wheel controls for the radio?
Thanks!
Dont believe there is any. Do you have the interior like the pic I posted (minus bucket seats)? Mine is an LT
Some do and some dont it depends on model (Z71 appearance pkg has it standard) and year
Yes, will require a dealer to do a reporgram
Shouldnt be to difficult, I believe there is a write up in the how to section
Chevy's site says LT's get "deluxe" cloth. I know in my W/T 03 the seats were different than LS cloth seats (LS being the middle trim back then and LT being top).
I don't have the silver(?) looking pieces on the doors and dash and the controls on my dash are also flat black w/o a trim ring.
