4WD front hubs locked?
I've got a '01 Silverado Z71 that is acting like the front hubs are locked or engaged all the time. I notice it when I'm backing up and turning the wheel -- I can feel the tires grabbing in the turn. The 4WD seems to switch between Auto, 2WD and 4WD ok (no service light on either).
Any ideas?
It sounds like something isn't quite right in the front differential.
If I understand the 4wd correctly on these trucks the front hubs are always locked and the disconnect for the front axles is in the front differential.
When you are in "autotrac" the front differential should be engaged but the transfer case is not unless rear wheel slip is detected.  If you are in 2wd the front differential should be disengaged as well as the transfer case.
If you have warranty left on your truck, you may need to go see the dealer.
The problem I'm describing happens when in 2WD (the light indicates this). It problably happens in Auto as well, but I haven't checked (I usually use 2WD all the time except in wet conditions when having 4WD lets me start without slipping). I really haven't used Auto much.
when your truck is parked, reach underneath and try to spin the front drive shaft by hand, if everything is disengaged as it's supposed to be it should spin freely, if the front axle actuator or slide is stuck the drive shaft won't turn. Being electronically controlled this could check ok when parked, but have an electrical problem causing the wheels to lock when not needed.
When parked and engine off, the drive shaft seems engaged (I can't turn it by hand). A friend of mine mentioned that the control mechanism up front sometimes sticks. He said you can pull it out and see if it frees up the driveshaft. Unfortunately he's not around to have him look at it. Do you know which side underneath this is at? If I can find it I can see if this helps. Does his suggestion sound reasonable?
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
