tranny swap
Hi Guys.  :cheers: This is my first attempt at this forum so please let me know if I am in the right place. Here is my problem: I have a 1989 Suburban Silverado 4x4 with a 700R4 tranny that does not shift out of 2nd gear and slips like crazy in reverse. I have three 700R4's at home out of several 88 caprice classics that have 250,000 + but run perfect. Obviously the tail shaft is different but my question is can I take the tail shaft from the blown tranny and put it on the good 700R4 or maybe take the innards from the good tranny and transfer them to the bad one? I love this truck and am desperate to keep her.  :flag: If you have any other suggestions please let me know. BTW I have had this tranny rebuilt twice now and am ready for a more permanent fix.
You can swap innards.  Before you do make sure the case is the same( 4WD mounting to tranny case).  We used to do swaps like this all the time.   There is a boat load of pieces inside of a 700R4, and the job is not for the faint of heart.  There may be differences in a deeper pan and filter pick up, servos, springs, clutches, sprags, valve body, etc.  You may want to seek the advice of an experienced tranny mechanic for his input.  Good luck with your swap. :cheers:
If your spare trannies are from behind V-6's or small  V8's they may not be as heavily equipped internally as your truck model (less clutches) but that won't matter if your not using the truck "hard" often. The two exterior differences between a car tranny and the 4WD model are, no provisions for bolting up the heavy dust cover over the flywheel, and the output shaft of the transmission is longer on the car model, too long to slide the transmission and transfer case together. I've heard you can shorten (cut) the shaft and use the car tranny but I've never done it myself, the other alternative would be to swap the mainshaft from the truck transmission into the car transmission, or put the car internals in the truck case with the truck mainshaft, either option would require complete disassembly of the transmission.  ???
    HWN808
    HWN808
  • Who's Online   3 Members, 1 Anonymous, 866 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
