Ddm Tunning Fod Light Kit
anyone buy the DDm nnbs fog light kit? it claims to be plug and play and it def is Not. anyone buy this kit? am i missing something?
I assume you are talking about the two wires with spade plugs they expect you to insert into the factory plug? You can always just cut the connector and use butt connectors to connect them or you could use t taps and leave the stock connector.
Of course that is just guessing at what you are talking about.
mine wasnt plug play either and the spades they came with did not fit into the stock connector(spades were too big), i just tapped into the wires and left the plug there incase i need to put a stock bulb in at some time. and just wrapped the stock connector in electrical tape to protect it from road grime.
i have the ddm fog kit for mine, the spades were just a smidge to big, with some mild persuading they slide right in with no damage to the stock plug...
I ordered a true plug and play kit from Spencers Hids. If anyone wants the ddm kit ill sell it for $40 bucs. They wanted 20% restocking so **** them, id rather sell it to someone who wants it, ill never buy another kit from ddm ever again.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
