Tosh.0
tanked_darren
I love it. While in the hospital with my daughter they were running a marathon before his new special. I watched the entire season in a day.
Yeah I missed that marathon :dunno:
I love his shows and his standup ...... with quotes like "i'm gonna take you to pound town" and "im gonna tongue punch your mom's fartbox" how could you NOT love it :dunno:
his newest season isen't and funny as the last few..hes essentially the new dave chappelle lol "do you buy your grandma nice things? like a new front axle?"
I'd have to say I agree with you on him being the new dave chappelle, who also was quite funny
Saw 1 episode. Don't quite get it. Seems to me like it's just some DB adding commentary to Viral-web vids. I can do that, where's my show? :cool:
Maybe I just caught an off-episode or something.
watched his stand up last night...pretty funny "ever seen the alternate ending to the mighty ducks? they lose and go into the locker room and snort coke and jack off on each other while emmanuel is dead in the shower" hes just so crude lol
That's what makes him so funny! Entertainment at its finest :cheers:
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
