New From Montana
Out with the old in with the new! Picked up a 2011 GMC SLE All Terrain just before Christmas and I have been roaming around on here since last October getting up to speed on the new GM trucks. All my other trucks have been GM trucks except my last truck which was a 2004 Nissan Titan. It was a good truck for the 160.000 miles I put on her but it was time to come back to GM.
Picked up a lot of good information here (and bad, to many mods!). One of the best decisions was getting the 6.2L. As soon as I can figure out how to resize my pics I will post those.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
