98 Gmc K1500 Having Problems
when i go around 90km the spedometer starts jumping all over the place and the tranny will shift in and out of passing gear thinking it could be a VSS looking for other opinions before i start throwing money at it
Yup, definently sounds like a VSS issue. Make sure the transfer case output shaft doesn't have any excessive play. In and out or in any direction, really. Could be giving the vss a false signal. If not, I'd start with a VSS unless you can see any damage on the VSS circuits.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
