New From Dfw
Hey guys im new here. Im from Fort Worth, Texas. I have a 2003 Chevrolet Silverado with a few upgrades and more on the way.... my real baby is a 1970 Nova.
Looking at some more ideas for my silverado, just getting into the truck scene. Tell me what ya think...
I havent done much so far, I added the 20" Helo Wheels with 275/60 tires, I added all new headlight and parking light lens the old ones were very faded. I have added a billet grill and billet radio antenna. Plans are to have the front windows tint matched to the backs, HID headlights and LED interior lights, Escalade guage cluster and level the back with leveling shackles and add air bags for towing. I am also toying with the idea of painting the chevrolet emblems white, what do you guys think?
The Nova has just about everything done to it you can do lol.
1970 Nova
10 point chromoly cage
9" Ford rear end with ladder bar/coil over suspension
Wilwood disc brakes on all 4 corners
4" cowl induction hood
all autometer guages
565 inch big block chevy with 2 stages of nitrous
powerglide transmission
custom built nitrous convertor
etc.
Welcome and nice truck. I'm liking the Nova, takes me back to all the things I wanted to do to my grandmothers Nova when I was younger.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
