I hate the look of gold or brass on a vehicle. I have removed the tailgate bowtie and replaced the bowtie on my grill with a chrome one. Now on to the hub caps.
Here is what I started with. I masked off the area around the bowtie with black electrician's tape and blue painter's tape.
I started the gold removal with a red scotch-brite pad.
After removing all of the gold, I polished the remaining aluminum with buffing compound to remove the deeper scratches from the scotch-brite.
Next, I further polished with fine cut polishing comound.
Next, a coat of wax to shine it up nice.
Done. And it looks much better.
Thanks for the comments, guys.
Pics, as requested:
On the truck, before.
And after.
From a little farther away.
I never would have noticed this until seeing this cap separated from the wheel, it looks strangely like the old '67-'75 GM dog dish caps like I have on my K5.
Those would look a lot better if you removed the gold. :D
Seriously, though, the resemblance between the two is amazing. I would have to guess that it was intentional on the part of some designer at Chevy, going for a little bit of retro styling. Too bad most people will never notice it. Thanks for posting the pic.
Someone needs to send this to GM and tell them to stop putting gawdy gold accents on otherwise beautiful trucks :) .... totally agree, the silver bowtie looks much better!!
wow... very nicely done..... :)
amazing what difference a little colour (or lack thereof) can make!
That's a job well done there. I've always disliked the gold stuff on an otherwise silver/chrome accented vehicle. I did the same thing on my TBSS. The rear bowtie had a gold plastic insert and the wheels were the same as yours were.
I dunno...I like the gold accents. Not that the hubcaps at the top of this thread look bad, they do look nice. If the gold were something new that GM all-of-a-sudden started using, maybe I might not like it so much, but seeing little connections like that between my old Blazer and my new Silverado is kind of cool. Just my 2 cents.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 524 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
