At what millage should I change the Rear Differential Fluid?
I went to Goodyear this morning to get a Nail removed from my Tire and the suggested it.
I think I'm around 55,000
There was a thread here this week about changing it out about 1500 miles or so once the rear end brakes in so if you never did that it might be a good idea.
I don't know what the manual suggests. I usually have the transmission, front and rear diffs, brakes and the cooling system fluids all changed/flushed (obviously not flushing diffs) about every 3 years regardless of miles driven but that usually comes out to about 35-40K miles. My '10 Sierra only has 3k miles so nothing has been changed on it yet. May change the oil in it this weekend so I can get some synthetic in there.
Sorry for all the extra info. At 55K, I'd say change all the fluids and I'd do a BG Flush on the trans, brakes and cooling system.
Agreed...at 55k I would do it as well, and as a licenced tech and service manager at a Goodyear up here I would also recommend it to my customers.
Of course we want to make money, who wants to work for free... but fluid changes at regular intervals is not a scam, it's called maintenance. Without it you would go to the dealer and bitch that the truck you purchased was a POS because it didn't last forever on fuel alone.
Really...not trying to start crap, but too many people on this site calling dealer tech's and others scammers that have no knowledge otherwise. We should really be a little more curtious to those that make sure we all get to work on time and are able to pay our bills...
and yes, even the repair ones :)
BG is too expensive, and if your gonna use their warranty to back up their price thats BS, ever looked and their maintenance schedule to keep the BG warranty? its ridiculous WAYYYY to expensive
Where can I find a how to on changing the rear dif, trans, coolant, and brake fluid?
Diff, tranny and coolant are easy BUT if you are looking for a how to on brake fluid I suggest stay away, I know everyone has to start somewhere but brakes are something you dont want to mess up, it is best to learn by watching someone who knows what they are doing a few times and then attempt yourself.
What have you been quoted to do a BG flush and on what components did you check?
I paid $158 for a BG trans fllush including everything. This was last year. Not bad in my opininon since only a flush will get all of the old atf out. I was curious what you thought was "ridiculous and way to expensive" of a price and I had a feeling you wouldn't remember the price. I'm not getting on you but some are quick to down a suggestion with no backup info.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
