06 Sliverado Lift Kit Question
Im very new to the forum, and have a couple of questions that hopefully can be answered. I will be honest, and I am fairly ignorant when it comes to anything over a leveling kit. I really didnt want anything bigger than that, but i have a friend who is selling his 6" kit off of his truck for a deal that i couldnt help but to consider it. My first question is how extensive would it to remove such a kit off a truck. Also is it possible to make a 6" to 4" kit? I dont really want that big of a kit, and 4" would be perfect in my book. Any help would be highly appreciated!
Also would 3" torsion keys in the front, and 2" blocks in the back be a better alternative overall. I know the kits are cheap, and I have heard of people being able to tuck 35's on this body style. Thanks again
No, its not possible to alter a 6 inch lift to 4 inchs that I know of. You might be able to tuck 35s with keys and blocks, but thats gonna put some stress on the front end. Also just about guarantee 35s would rub with that set up. Just depends on the offset of the wheels.
Thanks for your help! I probalby wont get the kit then. Im going to be using stock 17's, I have researched a lot of people using the same wheels with the RC leveling kit and being able to tuck 35/12.5/17's by just trimming the valance and a bolt in the fender wheel.
just for question, how much is your buddy wanting for the lift? my plan for my 06' is to use a 1" wheel spacer with 16" craigers i just ordered from summit rollin 35's and just crank my torsions up a little bit (i have the 2.5" leveling kit but am only using 1.5") and adding a 1.5" BL. i really like the big tires and minimal lift look myself. but if your buddy is sellin the 6'er cheap enough hell id be inclined to take it off his hands :thumbs:
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
