Build Sheet
I'm wondering if anyone can help me obtain a build sheet for 2008 Silverado I am looking to purchase second hand. I haven't had any luck getting one from a dealership as they aren't overly excited to help me purchase a truck that isn't on their lot.
VIN# 2GTEK638081128355
I would really appreciate anyone who can help.
Thanks!!
Vehicle BuildModel: TK10543-2008 SIERRA SHORT BOX CREW CAB 1500 4WD Order Number: N02581 Gross Vehicle Weight: 3,178 Build Date: 08/10/2007 Build Plant: 1-
Option Codes*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
194 - EBONY 19I - 1SE - PREFERRED EQUIPMENT GROUP 59U - SILVER BIRCH METALLIC 6FU - 7FU - A31 - POWER WINDOWS A48 - POWER SLIDING REAR WINDOW A60 - A68 - AG1 - 6-WAY POWER DRIVER'S SEAT AG2 - DUAL 6-WAY POWER SEAT ADJUSTERS AJ1 - DEEP TINTED REAR GLASS AL0 - AN3 - FULL FEATURE FRT. BUCKET SEATS AP3 - REMOTE VEHICLE START ASF - HEAD CURTAIN SIDE IMPACT AIRBAG AT8 - AU3 - POWER DOOR LOCKS B30 - FLOOR CARPETING WITH FLOOR MATS B58 - CARPETED FLOOR MATS B85 - BODY SIDE MOULDINGS C5W - GVWR: 3175 KG (7000 LB) CE1 - RAINSENSE AUTOMATIC WIPER SYS. CF5 - POWER SLIDING GLASS SUNROOF CJ2 - AUTOMATIC CLIMATE CONTROL D07 - DCP - DF5 - DH6 - MIRRORS - VISOR, ILLUMINATED DK8 - DL3 - POWER FOLDING O/S MIRRORS E63 - FLEETSIDE BODY OPTION FE9 - FEDERAL CERTIFICATION EMISSION G80 - LOCKING REAR DIFFERENTIAL GU6 - REAR AXLE - 3.42 RATIO JD9 - JF4 - PWR ADJ. BRAKE & ACCEL. PEDALS JJG - JL4 - STABILITRAK - STABILITY CONTROL K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL KA9 - HEATED STEERING WHEEL KC4 - COOLER - ENGINE OIL KG3 - KNP - TRANSMISSION FLUID COOLER L92 - VORTEC 6.2L SFI V8 ENGINE MYC - 6-SP ELECTRONIC AUTO/OVERDRIVE N30 - NR3 - NT7 - FEDERAL EMISSION SYSTEM NZ4 - NZZ - SKID PLATE PACKAGE OSG - P41 - 20" CHROME ALUMINUM WHEEL PKG PPA - QSS - P275/55R-20" ALS TIRES (4) R7K - R9Z - SAF - SPARE TIRE LOCK SLM - SLT - SSB - T74 - T96 - FRONT FOG LAMPS TL1 - DELUXE GRILLE U19 - KILO SPEEDOMETER U2K - XM RADIO - INCL. 1ST 3 MONTHS U42 - UD7 - ULTRASONIC REAR PARKING ASSIST UE1 - ONSTAR TURN-BY-TURN NAV AVAIL. UG1 - UNIVERSAL HOME REMOTE UJ6 - UK3 - STEERING WHEEL AUDIO CONTROLS UK6 - REAR AUDIO CONTROLS UQA - BOSE PREMIUM SPEAKER SYSTEM UVB - NAVIGATION RADIO/RR DVD SYSTEM V43 - PAINTED REAR STEP BUMPER V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA V76 - FRONT RECOVERY HOOKS (2) VFF - VG3 - VH9 - VR4 - WGHT DIST. PLATFORM TRLER HITCH VT7 - VXS - XA7 - HEATED W/S WASHER FLUID SYSTEM Y91 - YD3 - YD5 - REAR SPRING BASE EQUIPMENT YD6 - REAR SPRING BASE EQUIPMENT YE9 - Z31 - PRELIMINARY INVOICE Z49 - CANADIAN BASE EQUIPMENT Z60 - Z82 - H.D. TRAILERING EQUIPMENT Z88 - ZRS - ZY1 - SOLID PAINT
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
