2005 Silverado Shock Rattle
lenrev
I have a 2005 crew-cab Silverado 4x4 with 6.0 and tow package that I bought new. It has around 44,000 miles on it, all suburban, no off-road driving.
I developed a rattle that is felt in the steering wheel, particularly at low speed, and most pronounced when the wheel is turned in either direction. I use a reputable shop for all maintenance. They researched the rattle and were advised of a service announcement stating the shock mounts were a known problem and they were replaced. While it initially felt better, the rattle was still there and became as before within two weeks and continues.
Anyone else had similar issues and found a solution?
You might check the intermediate steering shaft. Also check the lower steering column bearing
+1
+1
Change the shaft, your troubles will be fixed!!!!
agreed of interm. shaft.. I have the same issue. Im told its more of an annoyance issue tho than a safety. Some days its worse than others..
+1 on the intermediate steering shaft. You can either replace or relube it. I got the relube kit for mine about 50,000 miles ago, and it has been fine since. It will take you about an hour to do if you are slow like I am.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
