5th Wheel Trailer Tires
So we just picked up a new-to-us 5th wheel and the tires need some air added. I was looking at the tire and they are 235/16 goodyears, which indicate a max air pressure of 80 psi cold. The trailer is a 32ft 8k lbs unit. I am used to putting 40 lbs of air in my regular tires, do these need to be aired up that far (80 lbs) or is that a max guide. I don't think I ever put more than 50 lbs in anything I've owned....
--Mike
Mike,
I have a 32' Mobile Suite 5th wheel. I always keep the max tire pressure that is on the side wall of the tire. In my case it is 110PSI COLD. You probably have a 16" E rated tire and they run 80 PSI COLD. If you don't run them at 80 you over heat the tire and will blow one out. Also check the date that the tire was manufactured. DOT (XXXX). That is (1130) would be 2011, 30th week of the year. If the tires are more than 5-6 years old I would change them even if they have alot of tread left. If the side walls show cracking, change them.
Enjoy your new 5th wheel but tires are very important on a trailer.
Walt
You want to take max weight rating of the trailer and divide that by the number of tires (even though some load will be taken up by the truck). Then you look up your size tires on the TRA (North American Tire & Rim Association) Inflation tables to find the appropriate pressure. Take notice that the same sized tire has different ratings based on if its run as a single or dual, so that is a factor.
Here's a link that will help you determine the correct pressure:
http://marktg.toyotires.com/file/loadinflationtable.pdf
I would just Run the max that your sidewall says for COLD. I agree with everything Walt said above.
All good stuff, many thanks guys.
I actually replaced all my boat trailer tires last year just because I had one blow at the end of the previous year and figured the rest would be close behind...
  • 1 month later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
