2007 Tahoe Won't Start Please Help
Drum1strat
My 2007 Tahoe will not start. It was running fine but the tire pressure sensor popped up saying service. Also the keyless entry quit working. So I disconnected the positive battery cable for approx 2 mins hoping this would reset everything however it did not and now it will not start or even turn over. The inside light will not work also the door looks will not work inside and the keyless entry still won't work. The radio will work and is still programmed with the stations I had preset and the correct time also it says the traction control is off but when you press the button nothing happens any help would be greatly appreciated before my wife freaks out cause I tore her Tahoe up Thank you
Haven't had the chance to try and jump it off yet. I had to go in to work. Gonna try when I get home in the morning. I will update. It has me puzzled it was running perfectly fine until I disconnected the battery cable. Thanks for the advice
Tried jumping it off. Tried charging battery. Tried disconnecting both battery cables and holding them together. Nothing worked. Still wont start. I'm lost guess it's going for a ride on a rollback to the dealership. Thanks. Will advise the damage when I talk to the dealer
Bad starter or solenoid possibly
bad body control module. Dealership said it shorted out and fried the computer. Thank the lord I had a extended warranty. Still cost $110 but atleast it's running now
That is really strange. The body control module usually doesn't just short out. Well, I am glad you got it working again. Thanks for sharing.
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 331 Guests (See full list)
