Pittsburgh Blackbear Tuning Event
It was nice seeing you all. If I knew you guys were going to lunch, I would have waited... :fume: No worries though, I had a nice time seeing you guys and drooling over the camaro's
And to Justin, the truck ran awesome on the way home. Very pleased. Def felt stronger and I believe it picked up about .8 mpg better. Very nice seeing and talking with you again.
Thanks again.
And a Big thanks to Rich for organizing the event :cheers:
I see you finally changed your signature :)
One day I will have a camaro, hoping its a 2012 ZL1. Fingers are crossed.
I see you finally changed your signature :cheers:
Worth every penny. :)
And I agree, they are quite the machine. If I didn't like driving a truck, I'd have one of those....
It was nice to meet you Steven, Rich, And Kris. The truck feels like I have a new Tranny in it..WOW :cheers: .
I got a real good look at thye back of Rich's and Kris's Camaro's on route 28 coming back from lunch... I made it to 90 MPH and gave up.... :) Two BADASS cars!!
The shifts are a 100 times better, no shift lag and its alot firmer. It runs higher into the RPM's before it shifts, before I could get into all 6 gears in 100 feet. For what I spent on different mods this is one of the few that really made a difference.
Bet it was fun! Glad you all like the tunes, i know i like mine!!
P.S. The ZL1 will be one badass car, wish i could afford one when they come out!!
Thats my fear. My guess will be $55K +
In that case I will loose the "want". If it is $50K or less I would really think about it. Probably have to then hire a lawyer for a pending divorce :thumbs:, at least I would have a sweet ride :)
It was nice seeing you all. If I knew you guys were going to lunch, I would have waited... :lol: No worries though, I had a nice time seeing you guys and drooling over the camaro's
Thanks again.
:thumbs:
And a Big thanks to Rich for organizing the event :)
+1 ! I always enjoy meeting other members whenever I can, and putting friendly faces to all the posts we see every day. Thanks Rich & Justin!!! :)
Thanks again.
:thumbs:
No problem Steven,sorry about that,I didn't realize you and your son was going to Eat'n Park for lunch,or I would have stopped you and told you to wait a few minutes for Justin to get back from his 1:50 time slot tune,we had to hurry though so he could make it back for his 3:00 time slot customer.
No issue in organizing it,I like helping as much as I can,and I enjoy meeting all the guys! :)
It was nice to meet you Steven, Rich, And Kris. The truck feels like I have a new Tranny in it..WOW :lol: .
I got a real good look at the back of Rich's and Kris's Camaro's on route 28 coming back from lunch... I made it to 90 MPH and gave up.... :) Two BADASS cars!!
Sorry :thumbs: But were we really going "that" fast on 28?!?! :)
Well,we had to make sure that Justin tuned them correctly,yeah thats it....we were making sure all was well with the tunes!!
:):P:D:D
Thanks again.
:thumbs:
Good to see you again Pete! :)
I couldn't make it out today, I really wanted to but had to work and had stuff to do around the house. Sounds like you guys had a good time
No problem Tyler,but we expect you at the next one! :thumbs:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
