What Type Of Exterior Wax
They rolled my brand new truck off the transporter last month with a bunch of scratches on side. :thumbs: (Or the dealer prep guys did it?)
I just got it back from the bodyshop but I can't tell if it's any better with all the rain today.
I think they had to wet sand it. Buffing will only take out the very minor scratches.
Meguiers M105
*** Moved to the appearance and car care thread***
  • 3 weeks later...
Not tryin' to be an ahole, but you would use a polish or compound to buff out scratches, not a wax. The wax would go on after the sealant in an ideal application.
As for what compound to use, you ALWAYS want to go with the lightest one to remove the edges of the scratch. Not sure if "small scratches" means spider webs or scratches from something else. I would start with a polish and rotary buffer, if you have never used a rotary buffer be EXTREMEY carefull or you will burn through the paint.
After you remove the scratches use some paint sealant or wax (or both) and you're good.
Turtle wax scratch & swirl remover works well on lite scratches and paint imperfections. Depending on your paint best to wash well use the scratch removal liquid, clay bar, and seal than carnauba wax.
Or go to AutoGeek.com for products. I use team on my 2006 Chevy Silverado crew cab. They are a little expensive but well worth the money. It makes the red POP!
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
