Windshield Replacment
SAE09
Hi all, first post.
I have a 1999 GMC Sierra K2500, 5.7L I purchased new at the end of 98. The windshield was just replaced yesterday. There was a thin foam strip that runs along the top of the windshield opening, which sits between the edge of the glass and the body. It is no longer there.
What purpose does this foam strip serve? Is it simply a filler to keep debris out and deter ice from building up behind the glass edge? Should this be replaced? I am concerned that with the gap that is there now it can become a catch all for dirt, leaves, whatever, and could allow significant ice build up to occur.
Should this be replaced and is there a replacement part for this. Thanks
Rick
Its called a foam dam strip and its purpose is to keep the urethane that is
put on the pinchweld from squeezing out if the bead isn't run perfectly and being visible in that gap at the top.
When we install glass we don't use it either as it collects sand and grit and rubs
against the body and will remove paint in worst cases. Dodge trucks have gone
away from using it even at the factory.
Its also used by poor installers to cover up damage they have done to your
pinchweld during the old windshield removal.
Ok, I wondered what purpose it served as the glass company did not replace it. I can see foam being a dirt and grit magnet.
What are your thoughts as to the gap that is left there since the foam dam strip is no longer there? What kind of solutions are there to fill that gap up?
I picture ice/snow building up in the winter and the freeze effect of that getting under the glass and heaving it up.
Here is a crude exaggerated cross section representing the gap left by the lack of foam.
Thank you for your help, I greatly appreciate it.
Personally I don't mind it and I see a lot of vehicles come into the shop,
some have a little dirt in the gap but before we start we just hose it out.
Next windshield if the gap bothers you ask the glass shop to show you
a piece of universal molding that can be attached to the top of the windshield
(I would use a 17mm piece) and see what you think. One thing ask them
to run a bead of urethane along the molding to make sure it doesn't come off the glass.
Good thoughts, and I like the universal molding to finish it off for the next go around. I was thinking about the additional
bead of urethane. The gap between the glass and body is 4.5 - 5.5 mm depending where along the top its measured.
The other thing I forgot to mention as you may know, the glass has a black molding that runs around the entire edge
of the glass encasing the edge if you will, same as the factory piece that was in there.
Lastly, the top center of the glass, roughly 12 inches across or so, sticks up above the edge of the roof about 4 - 5 mm. So if you're looking
from the back of the roof toward the front, down the roofs angle to the glass, it sits proud of the roof by that much. I didn't show that in my rendering.
Thanks again for your advise. Have a great holiday weekend!
The black area around the edge of the glass is called the "frit" this is to stop the UV rays from
hitting the urethane and doing damage. As for the center of the window sitting up that sometimes
happens with some makes of windshields. They are made in the US, China and Mexico, some factories
will make a certain number for say GM, then remove the GM logo and produce aftermarket ones.
Sometimes these factories don't quite get them perfect. At our shop once the urethane bead is cut next
to the windshield we dry fit the new one on the old bead just to see how it fits before we cut away the
old urethane bead.
Hope this helps, nothing I would worry about... just a little sloppy.
Thanks for the "new term" glossary for both of those parts (foam dam strip, and frit), but even more so for the background on the mfg process and end product shape.
Sloppy I agree. I am going to ask them to apply a small bead of urethane across the top down into the gap to alleviate the settling of water/ice/debris.
Another question. Is it common practice to remove the "frit" and apply urethane underneath that to help adhere that to the glass or even to try and push urthane under the edges of it? Reason I ask is it appears that there are remnants of urethane strings and wiped edges around the perimeter of the frit.
I won't run a bead of urethane in the gap if I were you because the next time they go to cut the urethane bead to remove the window it will not be pretty.
The frit is paint that has been applied to the windshield and baked on in the laminating process and can't be removed, what you might be seeing is the vinyl
that is laminated between the two pieces of glass (if it is clear) if it is black its a messy urethane job.
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 576 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
