new to this site
Chitty Chevy
We are livin well  :cheers:
Welcome aboard better becareful it wont take long for you to turn into a  :flag: guy  :lol:
As a proud owner of an awesome 2002 Ford F-150 XLT Super Crew, I just thought I'd see how the "other half" of the truck world lives. See ya around.
Welcome ,
I love your screen name it is great  :thumb:
:( Been a loyal member of F150online for many years. Check it out sometime. As long as Ford continues to make a reliable product, "conversion" won't be possible. I used to buy GM products until I bought the car from ####, a brand new 1986 Pontiac Fiero 2M4. I take good care of my vehicles but even that couldn't help me with that POS. Since then, I have boycotted GM products and haven't been disappointed. My $.02 worth.
a brand new 1986 Pontiac Fiero 2M4. ISince then, I have boycotted GM products and haven't been disappointed. My $.02 worth.
Gm has come a LONG WAY since then .  Might want to step out of the past
:flag: Been a loyal member of F150online for many years. Check it out sometime. As long as Ford continues to make a reliable product, "conversion" won't be possible. I used to buy GM products until I bought the car from ####, a brand new 1986 Pontiac Fiero 2M4. I take good care of my vehicles but even that couldn't help me with that POS. Since then, I have boycotted GM products and haven't been disappointed. My $.02 worth.
I can understand that my dad had a 97 2500 GMC and it was an absolute POS and it parked inside never saw a gooseneck ball or even a hitch!!  He ended up getting it Lemoned and got a 99 new Body style GMC 2500LD and since then no probs  now it's a shop truck and he has a DMAX...but they all have their problems :(
Welcome to the site.  Nothing wrong with being a Ford fan.  My favorite truck is the Superduty, which I will hopefully have one of these years.  But I still love my Chevy. :thumb:  :D
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
