Useful Tips You've Acquired
Post any tips you have learned over the years that help keep your truck looking/running good, or just help the overall look of your truck.
iv learned alot just being on 2 chevy formums for almost 2 years now. cant really point out any specific things but my overall knowledge of GM trucks has increased a ton
Learned a lot from this site and a few others. Best tip i can think of, use google to search the site not the forum search.
clean your truck weekly, interior and exterior. dont drive fast, when you drive fast you put more wear and tear on everything.
if you do all that, you should have a solid vehicle in decent condition by 100,000 miles.
Keep your engine clean, clean the underside whenver you wash the truck, change fluids frequently, fix any problem ASAP, never let your balls overule your brain, drinking and offroading dont mix, make 4 trips to the hardware store instead of hauling all the rock/concrete/wood at once, check your tire pressure when you fill up, check under your hood when you fill up, go through your truck with a fine tooth comb after the winter, factory parts are always better than mexican/chinese knockoffs. These things have kept my vehicles running great at whatever mileage they were at.
what I've learned?
it's cheaper in the long run to pay a professional to detail the vehicle top to bottom at least once every 2 months..
it is far more expensive to buy all the crap and waste my whole saturday doing it, in addition if I screw up my paint I can't beat myself up (ok I could but I might look silly)..
I wash it and vacuum it once a week, but the complete detail is done by a professional, and luckily I have a guy that is more anal about detailing my truck than I am, he even gets under it and cleans out all the road grime from the frame, and takes the wheels off to clean the brake dust off the insides.. all for $120.. can't beat that..
what I've learned?
I need to find someone like that near me, sounds like a great deal.
Everett's DetailEverett's Detail
11519 Bellflower Boulevard
Downey, CA 90241-5304
(562) 869-5888
Old Guy (maybe in his late 60s) from Harlem.. been in this location since 1984.. Very Detailed and Knowledgeable Guy, good prices and hands down the most trust-worthy detailer I have used.. His shop doesn't look like much, basically an old Quick Oil Change place, but he owns the property so has very low overhead..
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 642 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
