Bump Stop Removal
will just add... try to get a 2 to 1 connector so you dont have to fill both bags one at a time and try to get the psi the same. A 2 to 1 will have the bags perfectly equal and no messing around with back and forth with the air hose and pressure gauge.
I'm not sure I agree with this comment. I have had this set up on my last two truck and really think that keeping the airbags separate is a good idea. Sure if you have them hooked together it is easier to fill, you don't have to check to be sure you have the same pressure side to side, but I don't think it will be as stable. If your bags are connected and you load something heavy on one side, or have a load shift from one side to the other it seems that the bag with the load on it will compress sending its air over to the bag with no load on it. If you keep the bags separate, this can not happen. Just my two cents!
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 1,218 Guests (See full list)
