Bed Rail Caps
bbqbill11
I have a 2007 GMC 3500HD Dually. I need to remove the bed rail caps to install some brackets for a tunneau cover. How do I remove the rail caps? They don't seem to be glued on. Are there clips holding it on?
chances are they wont come off very nicely i have a feeling theyll break some clips etc etc. but what kind of cover are you installin that you need to remove them for... i havnt had to remove any caps to install any cover on these trucks...
