Performance upgrades for new Impala...
MountaineerTom
Does anyone know if there are any kind of performance stuff for the new Impala's, like a Hypertech programmer or something?  My wife seen one the other day and said she might like to have one, which really caught me off gaurd because she never says she likes any kind of car.  Of course, I'm thinking of stuff to do to it already.
Thanks for any info,
Tom
Hmm, i've never driven one but here are the specs from Chevys site:
Engine   Type 3400 V6 SFI
3800 V6 SFI
RPO LA1
L36
 Displacement (liters/cu. in.) 205/3.4
231/3.8
 Bore & stroke (in.) 3.62 x 3.31
3.80 x 3.40
 Bore & stroke (mm) 92.0 x 84.1
96.5 x 86.4
 Compression ratio 9.6:1
9.4:1
 Block material  cast-iron
cast-iron
 Cylinder head material cast-aluminum
cast-iron
 Valves per cylinder 2
2
 Induction SFI
SFI
 Ignition system direct
direct
 Hydraulic lifters hydraulic roller
hydraulic roller
 Cam drive chain
chain
 Alternator rating (amps) 105
105
 Battery (SAE rating, cca) 600
690
 Recommended unleaded fuel 87 octane
87 octane
 Redline (RPM) 6000
6000
 Horsepower/kW @ engine RPM 180/119 @ 5200
200/149 @ 5200
 Torque/N-m (lb. -ft. @ engine RPM) 205/251 @ 4000
225/305 @ 4000
Suspension Specifications - Impala
Both Impala models feature a 4-wheel independent suspension with specially tuned MacPherson struts
at all four corners.
Impala Sedan Touring Suspension
Variable-rate front coil springs and nonlinear rear coil springs
Hollow 32mm front and 14mm solid rear stabilizer bars
Impala LS Sport Touring Suspension
Hollow 30mm front and 17.2mm hollow rear stabilizer bars
Steering
Power rack-and-pinion for both models
Steering Specifications
Ratio (overall)
- 3400 V6 engine
15.2:1
- 3800 V6 engine
13.3:1
Turns stop-to-stop
2.9
Turning diameter curb-to-curb (ft./m)
38.0/11.6
Brakes
Power-assisted 4-wheel disc
Standard ABS for Impala LS
Compact brake booster
Large brake components
Brake Specifications
Front Brakes
U.S. Standard
Metric
Rotor size (dia. x thick.)
11.93 x 1.26 in.
303 x 32mm
Total swept area
303.0 sq. in.
1955.0 sq. cm
Rear Brakes
11.0 x .43 in.
278 x 11mm
Total swept area
276.0 sq. in.
1781.0 sq. cm
Wheels
16-inch steel with Deluxe bolt-on wheel cover - standard on Impala Sedan
16-inch Custom aluminum wheel - optional on Impala Sedan
16-inch Sport 5-spoke aluminum wheel - standard on Impala LS
Tires
P225/60R-16 all-season blackwall - standard on Impala Sedan
P225/60R-16N Goodyear Touring - optional on Impala Sedan
P225/60R-16N Goodyear Touring - standard on Impala LS
Compact spare tire on all models
Transmission Specifications - Impala
4T65-E 4-Speed Automatic Overdrive Transmission
The 4T65-E transmission is standard on both the Impala Sedan and Impala LS.
Technical Features of the 4-Speed Automatic Transmission:
Dual-phase sprocket that drives two half-width chains rotating 180 degrees out of phase, helping
reduce the gear noise generated by each chain.
Family of electronic controls that help protect against over-revving the engine in low-range gears
and monitor changes in driving conditions to adjust and maintain optimum shift quality.
Long-life transmission fluid which is designed to need replacing at up to 100,000 miles of normal
service.(1)
1 Maintenance needs vary with different uses and driving conditions. See the Owner's Manual for more
information.
Type 4-speed automatic
RPO MX0 (4T65-E)
Gear ratios
First gear 2.92
Second gear 1.57
Third gear 1.00
Fourth gear 0.71
Reverse 2.39
Final drive ratios 2.86/3.05
Case material aluminum
Dimension Specifications - Impala
NOTE: All dimensions shown are inches/millimeters unless otherwise noted.
Exterior
Wheelbase 110.5/2807
Length 200.0/5080
 Width 73.0/1854
 Height 57.5/1461
 Tread width - front 62.0/1574
 Tread width - rear 61.3/1557
Interior  Headroom - front 39.2/996
Headroom - rear 36.8/935
 Legroom - front 42.2/1072
 Legroom - rear 38.4/975
 Shoulder room - front 59.0/1499
 Shoulder room - rear 58.9/1496
 Hip room - front 56.5/1435
 Hip room - rear 55.7/1415
 Passenger volume (cu. ft./liters) 104.5/2959.1
 Cargo volume (cu. ft./liters) 18.6/526.7
 Interior volume, EPA index (cu. ft./liters) 123.1/3485.8
Capacities Seating 6/5
Fuel tank capacity (gal. approx.) 17.0/64.4
 Curb weights, estimated (lbs./kg, est.)
 - Impala Sedan
3389/1537.2
  - Impala LS
3466/1572.1
Trailering(1) Trailer classification Light
Gross trailer weight (lbs./kg, up to) 1000/454
 Maximum tongue load (lbs./kg) 100/46
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 278 Guests (See full list)
