Swaybar Alignment After Leveling Kit
Has anybody installed a top mount spacer and had difficulty lining up the swaybar connections? The Kit I installed was the Skyjacker 2" level. Everything else moved into the correct place as it was tightened up the swaybar did not.
Its not really bad, but the rubber bushings did not seat exactly in the holes like they were before. I don't want to over tighten them as they are just rubber and will probably deform or break if I force them.
Truck is a 2010 Sierra Crew Cab 4x4
Just torque the nuts to 17ft/lbs, that's all you need to do. You wont be able to over tighten them, the nut will just strip out first. Don't ask how i know this.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
