Backup/Aux Light Solution?
I'm wanting to install a couple rear 50watt or so backup/aux lights ... with the "aux" part meaning I want to be able to control the lights from within the cab ... and want them on when in reverse.  I've searched/read most of the related threads within this Forum and it doesn't appear anyone has a complete solution for this particular application?
I found a set of K/C backup lights I like ... but they come strictly for tapping into the backup light wire ... don't really want to hook up a trailer with the truck in reverse and the E brake applied :D
Has anyone this themelves and have tips/suggestions to offer?  I have no problem installing the lights, soldering, etc. however I don't want to dismantel my truck in search of wiring, etc. and end up with a bunch of rattles in the end.
I just ran a few wires to a new KC switch in the cab, you have to manually turn on the KC lights, but it was very simple.  You can find a way to route the wires without drilling holes, just some zip ties and you're GOLDEN!!  I am definitely not an electrition, I dont even know how to spell electrition!  I like the switch, because when somebody decides to draft me (ride my ass) I can flip on those reverse KC lights and watch them cover their eyes and back WAY off!! Works especially well for that.
MOON...Does your truck have the snow plow prep
pkg?  Is there a aux. light switch next to the pass.
airbag cut off switch?   If not you can buy a
aux light switch from dealer and install like factory.
Check out Mountianeer Toms web site...He
has pixs and EASY instructions to install one.
............geo
............geo
You can use a 4 pod housing around the airbag shutoff and add a few switches depending on your needs.  I have 1 for my Hella's out front and another for the KC's under the rear bumper.  Looks factory and function is great.  Jason Pendlum has some install diagrams/tips if you want to drop him a line.
Just last week I posted in the 1500/2500 catagory the almost same question.   I was planning on the aux lights to be hooked up to a relay and would be activated by a switch so that I could turn them on when I wanted AND also wanted to find the back-up lights wire under the dash and run it to the relay ALSO, so that they would come on with the factory BU lights when put in reverse.  All I need is to find the back-up wire.  I did this same set up on my old Dodge truck and it worked great.   My son used to have a 90 GMC and you could see the back-up switch on top of the steering column near the firewall, but I can't see anything like that on my 2000 Siverado.  Does anyone know where we can find this wire?  There has to be a switch up there somewhere that is activated when the shifter is put in reverse.  Any info on this subject will help us out !!! ???
YA KNOW...I think if you have the factory
tow pkg.  One of the wires in the factory
bumper harness plug is for the back-up lights.
You can put it in reverse and use a test light
to check the factory harness plug for power
in reverse or Have a look in the owners
manual to be sure..........geo
Yeah, I already thought of that.  Only problem this truck didn't come with factory towing package.   The previous owner added the hitch, wiring harness, and transmission cooler.  Thanks anyway :D
The reverse wire can be found behind the taillights, as well as under the dash (if you like tracing wires)  It is a light neon colored green wire.  I have mine set up that way, they come on in reverse, and I can turn them on by a switch.  It works/looks great, really helps since I have 20% tint on my front windows.
Bandera..........I think the trailer wires are there
bundled anyway even without the trailer pkg.
GM only likes to make 1 part to fit them all.
Maybe its hanging there or already hooked to
your add on plug.............
Got my K/C back-up lights put on today.   Ended up doing it like it was recommended in the KC instructions--put the relay inside the left rear tail light housing so that when I put it reverse they come on with the factory back-up lights.   Then I also added another hot wire directly to the lights (by-passing the relay wiring) so that I can manually turn them on.  When I turn them on manually only the KC's come on. :eek:
GUYS.....for back  up light wiring etc.  Check out this
link.  Shows amperage,  wire colors, which fuse etc.
www.gmupfitter.com
bulletin #27
I wanted to do the same type of thing Bandera described.  I was thinking about using the cargo light switch to control the lights, that way I can turn on the cargo light and backup lights from the cab using a factory switch.  I was planning on running a wire directly from the battery to the lights, using a relay.  I would run a wire from the cargo light switch to the relay and splice it to the reverse light wire.  If this works I should be able to control the lights manually and have them come on in reverse.  Any reasons this wouldn't work?
Now that's a good idea.  Post the details if you do it, I wouldn't mind having something like that myself, especially if it's wired with the reverse lights too.  :thumb:
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,270 Guests (See full list)
