2011 Silverado Lt Dash Trim Removal
I have a 2011 Silverado LT, so it comes with the radio and panel that has the air vents to the left and right of the radio.
How do I remove the dash trim?
I know this is like the 1,000th question. But I have searched the entire net for the past 6 hours at work and cannot find anything!
If it is like mine all you have to do is pull really hard on it and it will snap out. There are a bunch of metal clips holding it on.
by searching the entire net you mean you searched porn site to porn site???
just use common sense start at the top right corner with your bare hands and work your way around, is really easy man!!!!
the thing is when you put it back on, the bottom left corner is a bit hard to put back in, you need to put the shifter on 1st to have some room to work, but you can take it off and put it on in about 1 minute tops!!!!!!!!!
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
