Howdy... Help For A Newbie Looking To Purchase A 2010 Tahoe..
New here...
I'll be trading my trusty 2005 Cadillac SRX for a Tahoe shortly; 4WD Certified Pre Owned , 2010 or later in LT or LT trim. I have some questions and after lurking and searching I thought I'd tap the expertise here:
  1. For those who have purchased a GM CPO vehicle, how does the 12-month 12,000 mile bumper work? If the vehicle has the original warranty left on it still (many 2010s I'm looking at still do), does the 12 month, 12,000 mile just get added onto the the original warranty? For example, if I purchase a CPO 2010 Tahoe with 25,000 miles with the original in service date of May 2010, the original warranty is for 3 years, 36,000 miles so does the CPO extend the warranty to 4 years and 48,000 miles so I would have until May of 2014 and 23,000 miles left on the balance? I have searched but have not found anything explicit on this.
  2. I'll be visiting dealerships over the holiday weekend, most of the Tahoe's available are fleet/rental returns and the inventory is low (as with all used cars). Is this a good time of the year, when do the fleet/rental agencies turn them over?
  3. Any specific issues/problems I should be looking for? I'm aware of the rear tire/suspension/drivetrain vibration issue. What are some of the problematic areas I should look carefully at?
  4. The age old question... Tahoe or Suburban? I needed a bigger vehicle and after taking a long weekend golf trip with some friends in a Suburban I was sold. 4 big guys with gold clubs, luggage and coolers on a 500 mile round trip... the ride was excellent, comfortable and refined hardly felt like a truck. That said... I've been going back/fourth between a Tahoe and a Suburban and decided that the Suburban would be a tad too big for the wife (petite 5'4"), the garage... Questions are... Does the Tahoe ride as well? Obviously I'll be test driving it but a 20 minute test drive is not a 5hr road trip. Will I have buyers regret because I'll miss the extra cargo space? One key difference is that I think with the Suburban I can load skis in the back whereas with the Tahoe I'd have to put a rack on the roof.
Thanks for any help with the purchase decision.
Our 2008 has almost 27K miles. Only issue was a faulty gas cap at like 1K. Knock on wood none since has been a great SUV. The Tahoe is plenty big for us (me my wife, 1-1/2 yr old son and 100lb black lab). If we have, no I mean when we have another child I am sure we will investigate a larger vehicle, aka suburban. Probably wait until the redesign in 2014?
The back windows go all the way down in a Suburban, not so in a Tahoe. I reaally disliked that.
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
