1993 K1500 4hi 4lo Light
WHEN I PUT THE TRANFERCASE SHIFTER IN EITHER 4HI OR 4LO light stays on for wile then goes out for a wile off/on. seems like the front ifs axle disengaes when the light is off. shifts smooth other than the light and in and out.does the light on the floor have any thing to do with engament . :banghead:
  • 4 weeks later...
WHEN I PUT THE TRANFERCASE SHIFTER IN EITHER 4HI OR 4LO light stays on for wile then goes out for a wile off/on. seems like the front ifs axle disengaes when the light is off. shifts smooth other than the light and in and out.does the light on the floor have any thing to do with engament . :cheers:
Surprised you haven't had a reply here yet. Would love to hear if you got it fixed or not?
When i was 16 i had a 91 silverado with that Manuel transfer case, and from what i remember i always made sure that light turned off. I totally forgot i owned that truck haha
Light On:front axle engaged
Light Off:dis-engaged
The prob with the actuator is it's gas filled.It takes a while for it to get warm enough to push the piston in to engage the diff.Not sure when(maybe in the late '90s)GM went to an electric system where it engages almost immediately.They have an upgrade where you can replace the gas actuator with the newer version...I've been thinking about doing this...not cheap though
There's also a system called PosiLock.There is a handle you install(after installing the new actuator in the diff) under the dash(usually) and it locks immediately.There other advantages to it too...Google it :dunno:
  • 1 month later...
    small navy
    small navy
  • Who's Online   3 Members, 0 Anonymous, 876 Guests (See full list)
