98 Suburban Starts Then Dies - Help!
dajohnguy
Greetings,
I have a stock 98 GMC Suburban 2500 4x4 that is driving me nuts. She sat for a little over a year. Put a new battery in her & about 2 quarts of oil, & Also about 3 gallons of fresh premium gas. Car starts then dies immediately - security light flashes for 3 seconds then turns off - so its not a passlock issue - even did a relearn a cpl of times for shits & giggles - no fix - she isnt thowing any codes on the reader whatsoever - fuel pump is pumping and swapping the fuel pump relay with another one made no difference -I've also dribbled fuel into the throttle body while having someone turn her over- no go- I suspect a sensor or something small and simple is telling the fuel pump to cut off & causing all this aggravation- I've read many posts with tons of people with the same problem but no one has a solution - I've been told could be anything from the fuel filter, maf sensor, oil pressure switch or sensor, the whole ecu, and a bunch of other things. I honestly dont have the money to buy miscellaneous parts to see which one it is. W/o any codes or money for a top mechanic I'm pretty much in the dark here. Any help or suggestions on this would be greatly appreciated as I really need to get this beast up and running ASAP. Thanks for your time -
JG
it could be an air related issue. check the air filter make sure its clean. Also take off the air fuel filter and take a look at the gas that comes out and see if its not too dirty. If its not those two things my next bet would be on the fuel pump, it doesnt have the pressure need it to kee the engine running. i believe the pressure has to be between 61-66 psi.
thanks for the reply I really appreciate the input - air filter isnt too bad - fuel pressure is ok too until w/e it is shuts off the pump - gas doesnt look that dirty but was told by an old timer that it sure didnt smell so great- will put some sta-bil & seafoam in the tank later today to see if that makes a difference - any other ideas/suggestions?
thanks mark probably so I got the car like this and am trying all I can to get it running ---- genius today i repulled the fuel filter & this time put a bowl underneath it to try and see what I could pour out of the filter - what came out was pretty nasty looking:
i replaced filter & cleaned maf sesnor - rechecked all fuses - car still wont run - starts and then dies a second or two later - please tell me Im not gonna have to drop the tank!!!!! :thumbs:
  • 3 weeks later...
take out the new filter, and check if its dirty, if it is, then yes you might have to drop the tank and clean it.
thanks- i pulled the new filter today & there were no major chunks or dark colored gas like the last pic I posted- also did another fuel pressure test and took a video for you guys - please let me know what you think:
I've read the recommended fuel pressure is 55-65 psi - do you guys think my fuel pressure is so low that I need a new fuel pump? Please let me know as I have the tank dropped at the moment & plan to put it back up in a couple hours. I also bought an oil pressure switch out of desperation that I'll be installing later (or not per your advice). I dont know what else to do & really need to get this baby running - I'm sure someone must have had or seen a similar problem with a 98 vortec 5.7l - anything worked for you guys? - any suggestions? I'm running out of time & up for any and all recommendations - it would be truely appreciated.
Bless
-JG
If that engine doesn't have AT LEAST 60 psi, it isn't starting or running correctly. If you have less than that, time for a pump.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 547 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
