4l60e Issues 07 Gmc Sierra 1500
hey just looking for a little diagnotsic help here, the transmission is an 07 4l60e, in a gmc sierra 4.8L, basicly it ran fine then was parked for about a year, and now it isn't shifting right. it starts in 2nd gear and stays there when its in the drive range, it has manual first, manual second and reverse, initially it set the mil and the digital shift indicator in the dash disappeared , and had 2 codes p0700 and p1815, so i replaced the neutral safety switch and the valve body pressure switch assembly, reset the computer after that and the reset the indicator started working again and no code so i test drove it and same problem after i shut it off and turned it back on again, no shift indicator in the dash any more, and now no codes, did i mention it only has 20k on it, and the pan was crystal clean... like new, no sediment even. lol im pulling my hair out. p.s. also tried pulling battery and wiring harness to TCM and ECU to check for moisture issue and re plugging they looked clean and brand new, no signs of moisture. has anyone experienced an issue like this this before?
The first thing that came to my mind was that there was water in the trans fluid, but by the sounds of it you flushed it out. Does the truck still have a warranty? If so I would bring it to the dealer and see if they can diagnose the issue.....
its out of the 3 year and no extended warranty and there was no signs of any contamination in the trans of any kind, it looks like it just came off the lot,
If its a 2007..you still should be under the 5yr 100,000 powertrain warranty....I think anyway..
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 0 Anonymous, 737 Guests (See full list)
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
