Mirror Swap
i found koolvue GM73EL-S and GM73ER-S mirrors. they are the 2 lens tow mirrors with signals. both for less than $200. what would i have to do for wiring
I need to know the wiring differences
If your present have turn signals and are power heated it should just mount on. I would imagine that if you don't have the features they should still connect but have extra wires.
Since you've got a 03+, the mirrors are on a sort of data system in the sense that they connect to the window switch and it runs mostly off data. So they should be a simple plug and play, and if the signals don't work after it's said and done, get em' programmed.
I am looking at the same mirrors. My understanding is, if you already have power mirrors with heat these mirrors will plug in to your existing plug and the signals will work!
from what it says, it has dual connectors. i like the mirrors and for $87 each why pass them up
thats how i roll. possibly going to the 09 all terrain wheels
