Help In A Paint Job
hi
I've got this C10 86 and thinking of re-painitng the whole truck, but im re-thinking of painting it a jet stream blue that comes on a Zr1.
So any advices?
another thing, should i go with a metallic paint or a pearl paint, if i decided to go with the factory paint.
I like the jet stream blue like on the corvette(sorta, eh not really), don't get me wrong, but being as your truck is gonna be classified as classic in the next couple years, I'd repaint it original.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
