Low Airflow From Dash Vents
Hi All. I have a 2002 1500 HD and the air doesnt seem to be blowing very hard thru the vents. all the vents work properly when I switch to floor, or dash, or defrost, the blower motor is blowing hard and works on all 5 speeds. Just changed the cab filters and didnt really change things much. I know the blower is blowing hard because I turned it on when I had the cab filter access door removed and had very high airflow coming out of the open access door. Has anyone of you had this problem too? what was done to correct it?
Thanks in advance for any help
Paul
Paul
When you switch it to the vents is it blowing anywhere else as well. Sometimes the little actuator doors dont open or close fully so the air will be diverted to other areas as well. If its not coming out strong on the center vent near the radio i would guess this is the problem.
I dont think the air is blowing harder in the center vents. i checked to see if some is coming out the defrost or the floor and dont feel anything. i would like to find a schematic or drawing of the air box that shows where all the actuators and doors are on this thing. haven't had much luck finding that
  • 3 months later...
