Was out by JP again
CMNTMXR81
And I saw nothing but GM HD's, Ford SD's, and one new Ram HD.  Of particular about the GM's, it was a 50/50 split between the old 01/02's and the new "ugly" 03's (all Chevy but for 1 GMC).  Someone out there is liking them, otherwise they wouldn't be selling as many as I saw.  And don't make any wise remarks about farmer's tastes otherwise I'll have to tell JP.  :D
Completely off topic, but doesn't Dixon have something to do with Ronald Reagan  :D  I'ts been awhile since I've been there but I think he went to school there or something?
Who knows. Maybe the people buying all those "ugly" Chevys think they are ugly too. They just knew better than to buy anything else. :thumb:  :lol:
It's the hometown of Ronald Reagan.  Funny thing was, he was born a little bit away (south) from Dixon, only lived in Dixon for a few years when he was young and then moved to California for the rest of his years.  So I find it odd that Dixon makes such a big deal of it.
Right, he was born in Tampico, raised in Dixon, went to college in Eureka.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
