3 Inch Body Lift With 6 Inch Bds ?
I have a 2011 Silverado, with a 6 inch BDS lift and 33 inch tires. Love the truck and the ride quality, but was pondering the idea of adding a 3 inch body lift. Will the body lift effect the ride of the truck or the 6 inch BDS suspension. Pro's and Con's please. Thanks
It will make it a bit more top heavy and handle different obviously...imo unless you are going to get 35s it will look stupid that high with only 33s
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
